dlundblad Joined Sep 30, 2013 Messages 16,273 Location Indiana May 10, 2015 #1 Pardon my ignorance, but shouldn't the knuckle be making contact with the axle? The bottom bolt is as tight as I can get it.
R Roadkingnc Joined Jul 16, 2011 Messages 737 Location NC USA May 10, 2015 #2 Upper ball joint is improperly installed, it should be pressed in from the bottom before the knuckle is installed
E exranger06 Joined Jan 25, 2008 Messages 4,464 Location Guilford, CT May 10, 2015 #3 Originally Posted By: Roadkingnc Upper ball joint is improperly installed, it should be pressed in from the bottom before the knuckle is installed This.
B barkingspider Joined Dec 23, 2013 Messages 2,458 Location socal May 10, 2015 #4 Roadking is correct
dlundblad Thread starter Joined Sep 30, 2013 Messages 16,273 Location Indiana May 10, 2015 #5 Very interesting. The whole steering thing intimidated me so I just had it professionally installed about 4 years ago when I bought the axles. (They've just been sitting since.) I didn't know (and still don't know) much about the topic. I don't know if its installed wrong though: http://www.wjjeeps.com/service/knuckle_upper.jpg *But it makes sense you would want it to push up against the axle rather than up and out of the axle. Lol. Last edited: May 10, 2015
C Chris142 Joined Jun 5, 2003 Messages 28,029 Location Apple Valley, California May 10, 2015 #6 Where's the boot?
eljefino Joined Jun 15, 2003 Messages 40,479 Location ME May 10, 2015 #7 Only one ball joint is load bearing, you just have to figure out which one it is. Were you there for its disassembly, and is the shank rattling around loose inside the knuckle?
dlundblad Thread starter Joined Sep 30, 2013 Messages 16,273 Location Indiana May 10, 2015 #8 Originally Posted By: Chris142 Where's the boot? With the rest of the hardware.
dlundblad Thread starter Joined Sep 30, 2013 Messages 16,273 Location Indiana May 10, 2015 #9 Originally Posted By: eljefino Only one ball joint is load bearing, you just have to figure out which one it is. Were you there for its disassembly, and is the shank rattling around loose inside the knuckle? No. I just kept the knuckles off. I guess this poses an issue? Lol.
JHZR2 Staff member Joined Dec 14, 2002 Messages 52,855 Location New Jersey May 10, 2015 #10 Originally Posted By: Chris142 Where's the boot? +1
dlundblad Thread starter Joined Sep 30, 2013 Messages 16,273 Location Indiana May 10, 2015 #11 So all I need is the boot and I'm good to go?
