Originally Posted By: fdcg27
Clevy, at what ratio do you run this oil in your fuel?
I'm asking because I've been playing around with UCL adds with the older Accord and want to give TCW3 a try.
After all, what fun is an old beater if you don't play around with it?
My Chevy tanks are 100 litres. I add a quart bottle prior to filling up on an empty tank.
So 100-1 however I don't suggest running that stiff right off the bat. I found it best to start small and record fuel consumption then increasing dosage until no more positive effects are noted.
My charger is best at 1/2 a quart at empty fill up. I think it's 19 gallons.
That being said the newest vehicle I'm doing this with is my charger which is an 06. My c3 is an 01 and 2 1999 silverados.
I've been using this ratio in one of the silverados for in excess of 100000kms,truck now has 290k on the odo. Original catalyst,original O2 sensors and no cel's on.
And I get better than EPA rated fuel consumption in everything. Even my high mile trucks get better than 20mpg on the highway.
There's also 1/2 quart of toluene/xylene or acetone mixed into my fuel.
If starting from scratch I'd go with an ounce per 5 gallons and increase from there.
