[/quote]
And I have no problem with that line of thinking. It was the absolute terms used in your bold and caps-lock post that rubbed me the wrong way. My point was that these tests are ALSO marketing material. Specific tests chosen to show a product in a particular light based on their performance in that test. It doesn't mean that this level of performance; this top-shelf achievement is across the board. Of course that's the designed take-away but it isn't the truth. Oils are all a compromise designed to at minimum meet all the performance requirements for a given suite of tests so they can check all those boxes.
The oil that does the best in the Seq. IVA may not pass the Porsche A40 certification process for example. And the oil that does the best in the piston cleanliness test may not do all that well relative to its peers in the Seq. IVA. That's why my approach regarding lubricant selection is to favour the oils with the most OEM approvals, which generally points to a Euro-spec product. Within that envelope are then products that can be contrasted based on some additional metrics like cold temp performance (CCS and MRV). Of course this is a bit more difficult if you have a xW-20 spec application
It would be nice if the oil companies were required to publish their results in all of the sequence tests for their products. One could then choose the appropriate product not only based on it being approved for their application but then on its performance in the test or tests that most closely resemble their operation conditions. [/quote]
Peace, Caps lock was not as intended. Maybe more out of frustration all the claims and chat about oils without anything to back up statements (im not talking about you)... relevant or not at least Amsoil publishes something I dont know anyone else who does post as many tests with their product and others.
Do I believe they may not publish anyone who exceeds them? Sure ... but at least with the one compared you have something.
As far as Porsche, well, not in my league. But understand your methodology for as many endorsements as possible for one oil which makes sense, again with your Porsche statement.
My issue is unrelated to this thread so do not want to post to much and will not reply anymore out of respect for the thread end it with this statement. I have a new Harley, they recommend their oil only OR a CH or higher oil. Thing is, no one that I can find but Amsoil makes a C rated 20/50 oil except Citgo owned Mystik, with Mystik (ill have to check again) even though they claim its a CJ4 oil, I do not THINK it has the API starburst. So Im unsure but most likely going to go with my trusty Valvoline Conv MC oil even though its only S rated.
I can use a 15/40 but do not want to in my hot climate. The reason for not using Amsoil is cost. I change every 2,500 to 3,500 miles I cant see paying $11 a quart and its not easy to buy. To do the limited use of the bike, I rather change a few times a year then run a whole year with the same oil. I can understand I maybe wrong in this but thats is my personal feeling.
