Originally Posted By: grumpy
The real question, neither asked nor answered, is "Does it use any oil between changes?" If the oil is checked before each use, and no oil is required to be added between changes, then the consumption is minimal. It is normal for all engines to consume a bit of lube, it would be abnormal for an engine to not consume oil.
Were it mine, I would ignore any startup smoke if the oil level remains consistently in spec. If the oil level rises, be concerned for gas contamination due to carburetor needle & seat failure.
I usually change once a year, and have never had to add oil between changes
