Originally Posted By: Shannow
As per my bearing tutorial (for want of a better word), bearing side leakage is affected by viscosity....demonstrated
in this paper where a main bearing was removed from the engine oil supply and provided with oil of varying viscosity, coming up with this result.
For a given supply pressure, oil consumption through the bearing was related to the HTHS (not KV in non newtonian oils).
The non Newtonian bit needs further analysis. A straight Non VIIed oil has no difference between it's kinematic and HTHS behaviour...a multigrade with VII has two behaviours depending on shear rate.
The test has to be under high shear rates, 10^6/sec or thereabouts...engine in the above test as can be seen, depending on oil to be in the second Newtonian phase at around 3,000RPM.
Your viscometer needs to have a built in understanding of this.
CATERHAM's premise is the inverse of the above, in that he's using a pump of constant supply volume (he needs the relief closed, as per his assertions), and measuring the backpressure generated from the bearings. He is getting positive correlation between the HTHS and the oil pressure thus obtained, and I beleive that his test is quite accurate.
However, if you are using the viscosities recommended by the OEM, there's a pretty good chance that the oil relief is flowing, and depending on design, may have a lot of squirters, cam phasors and things that are sending volume through pressure/density, and KV low shear flows.
My question for your in service viscosity checking tool is what can you do with it...if you are monitoring for fuel dilution and permanent shear, I can see some merit.
CATERHAM asserts that as long as your oil pressure is higher than the OEM min oil pressure (for their recommeneded grade, in an engine considered "OK") that the viscosity is adequate...keep dropping viscosity until you've got minimum OEM oil pressure.
I maintain that the viscosity measurement obtained IS sound, but that tells you nothing about the behaviour of the loaded side of the bearings, pistons etc. as you don't have the manufacturer's understanding on where on the Stribeck curve your engine started...Minimum OEM oil pressure on their designed lubricants is a condemn limit, not a target.
Shannow, this is the most even-keeled summary of your two positions I have observed. Thank you. I wonder if CATERHAM agrees...
