Originally Posted By: abycat
I don't think syn or dino makes a downsdifference with these engines. I run the syn cause I only get it on sale so it's cheap. Great car though. Mine had been great. I am almost at 60000km. We need to do our plugs at 100000 but I might do mine at 90000 if we keep it that long. I also want to do a drain and fill on my tranny but I only will put in the nissan fluid. I think it's matic d. I want to in a couple years trade it up for a suv. The winter up here is hard on cars and we want a bit more room.
Get a bunch of drain plug washers for yours if you havnt. They are special crush ones that are supposed to be one time use. I get mine from nissan. smaller rolled edge facing plug head.
I agree, they are great little cars. Simple, no frills. I just replaced my plugs, intake manifold gasket, serpentine belt and coolant last month (102k miles). The plug change made a really noticeable difference in the acceleration when I get on the freeway. The only downside on changing plugs in the MR18DE engine, is that you're forced to remove the manifold in order to even get to the them...kind of makes it a pain but oh well.
I took it to the dealer when I first bought it to have the tranny fluid changed. You're right, it is matic d. I'm thinking about doing it myself the next time around and using Maxlife tranny fluid, since it's listed as being a compatible replacement for Nissan's matic d.
I don't have a need for the washers, because I also installed a Fumoto valve when I bought the vehicle, but I think I have seen those crush ones that you're talking about. They're copper, right?
