Originally Posted By: Trav
Install the new fittings (take the ones you removed and match them at AA, AZ, Napa) then do your flair. You can tell which type of flair you need from the line left in the old fitting. Do not forget to put the fitting on first!
Be careful with the 3/8 vs 10mm fittings! A 3/8 will thread into a 10mm hole but could later blow out.
A 3/8 open wrench will fit over a 3/8 but not a 10mm.
They generally use 10mm for ISO/Metric flares. These nuts are generally not threaded all the way to the flare. Conversely, 3/8" nuts are threaded all the way, and end in a double flare. You might find both, because GM is "that way".
Quote:
Some lines to the master cylinder have coils in them, you can duplicate this by carefully wrapping the line around a glass bottle.
IIRC my Century might have had that braided flex line between MC and frame rail. It's there to relieve metal fatigue and vibration as the firewall flexes slightly in relation to the frame. A couple coils does the same thing. I've seen some artful ones but a rookie will probably end up with ugly stuff.
