I have a Honda HS720 snow blower that I want to put away for extended storage till nest winter..What is the BEST way to do this....
1. Drain the carb, put oil in the cylinders and remove spark plug
2. Fill gas tank with high octane gas, add stabilizer, run for few minutes, then start and run it every week for 10 min. adding fresh gas and stabilizer as needed??
3. Or any other suggestions
thanks
thanks
