Originally Posted By: SJohnson
Originally Posted By: DuckRyder
Champion Labs and FRAM are now "Fram Group". (AKA UCI - Fram Grp, AKA Fram Filtration)
Having cut open both SP5 and Ultras, I don't find them particularly similar.
I'm not knocking either filter. I like them both.
Yes, but they are still part of the Rank Group.
http://rankgroup.co.nz
I know, but Jay works for Fram group. (see his signature). When he says "We make" or "Fram makes" it could be a Champion filter and still be "Fram". The SP5 is pretty obviously a Champion Labs filter, which is also a Fram Group filter.
I know the Ultra has two layers. Did you notice if the HD filter did also? Also, did you notice if the wire mesh was stainless? I read somewhere that the Ultra mesh is.
Thanks.
The SP5 has at least two layers if you count the gauzy part I mentioned.
Next time I cut them open I'll see what I can tell about the mesh, assuming Jay doesn't answer before then.
Thanks.
