Last september I bought a car which had it's oil changes more or less at the required intervals - 10.000km -, but whose previous owner did not adhere to the "or once a year, whichever comes first"-rule. So the car had run 11.000km on one oil change - in six years. The following two changes had been made on time.
The result: when doing the third change (the first since I bought it) we drained not oil, but sludge and tar. Engine was shot, camshaft had seized in it's bearings (surprisingly, it was still running, although a bit rough).
Workshop did change oil two times following the repair, because the new oil instantly turned black. When I got the car back, I drove 1000km, then changed the oil - it was pitch black, like you would expect from a diesel. Now I've driven another 1500km and the oil is diesel black again... That engine is *still* full of sludge.
Don't take chances. If the car does not reach the km or mile based interval, it probably is not really needed. Still, you have it, pay taxes, insurances, garage/parking space... So your toy seems to be worth a lot to you. What does a "useless" oil change cost in comparison to all these other non-necessary cost?
