While just disconnecting the battery to reboot the ECU didn't work with my situation, after I had a terrible hesitation problem on acceleration, the car idled fine, and seemed OK when cold, but as soon as the engine would reach normal operating temperature the car literally would stall when taping the gas pedal. I looked at all the obvious issues with temp sensors, distributor, rotor, cap, ect...finally I was focusing on the fuel pump. Well before I threw down 400$ for a new pump I was playing with my basic read and clear universal OBDII scan tool. I accidentally left the ignition in accessory position (not supposed to do this when plugging in the code reader to the port) and saw the reader oddly show something it shouldn't have (reseting all ECM values to factory) and it automatically proceeded. Well right after that I went to start the car and viola, no more hesitation problem. I don't know what happened but it solved the problem and that 13$ scan tool is NOT supposed to be able to do a reset of all ECM parameters to factory values. But it did, and it worked...anyone else have an experience like this? Car was a 1996 VW Golf 2L.
Just to add the issue had been plaguing the car for months and never changed during in characteristics during that time.
