The battery on my truck was a Costco/Kirkland Size 78 mfd March 2008. I monitor its health with a Midtronics PB200 Conductance Tester. It drops about 50 CCA every year and last November it tested at 590 CCA, so I opted to leave it in for another year.
On Friday I went to a number of places and, when I stopped at my place of work, it would not crank. The battery would sometimes power up the headlights and sometimes it was too weak to do so, the headlight relay would just chatter. The battery was completely normal prior to this and I had absolutely no reason to suspect battery malfunction.
Anyway I pulled a size 31 battery off one of the trucks at work, put it inside the cab and hooked it up with booster cables to my battery under the hood and went home. Yesterday morning I went to Costco, picked up a new 78 and installed it on my truck.
With lights on the failed battery voltage would drop to 5V and keep falling and, as soon as the lights were turned off, the voltage would climb right back to 12.5V. I could also hear bubbling inside the battery. What kind of failure would this be on a seven year old battery? I don't think it is a short circuit since the voltage would come back to normal with no load. BTW, the failed battery tested at 380 CCA.
