A little long...
Application: 2002 Dodge Grand Caravan Sport 3.3L, 123,000 miles and with rear drums.
Objective: Will likely own this vehicle for another 80,000 miles. Want this to be the last brake job I do on this vehicle. Want low brake dust, satisfactory stopping power for a family hauler, and long pad/rotor life.
A little background: The previous owners had Raybestos ceramic pads installed not too long ago. Not sure exactly which ones, but I believe they are likely the Service Grade Ceramic pads which are semi-metallic. From the beginning the driver side was noisy. Recently I removed the pads for inspection and found, on the driver side only, there was inconsistent metallic material in one section of the pad. The relating section of the brake rotor had a deep groove worn into it as well. I believe this is the source of my brake noise and the reason why I'm planning another brake job. The brake noise is getting worse.
Three options I'm considering:
- Wagner ThermoQuiet CeramicNXT - Amazon, $28.55 shipped, minus $15 MIR; Total $13.55
- Bendix CQ Ceramic - Amazon, $38.99 shipped.
- Akebono Performance Ultra-Premium Ceramic Disc Brake Pads - Amazon, $69.35 shipped.
I currently have the Bendix CQ on my Honda with good results. No experience with Akebono.
Also, looks as though I'll be replacing my driver side rotor due to the deep worn groove. Might end up replacing both rotors for continuity.
Any other suggestions/advice?
Thanks!
Thanks!
