Originally Posted By: CATERHAM
I'm not talking about extreme cold conditions at all but rather even just moderately cold temp's at the freezing point and even higher.
Not with this statement you are not:
Sorry Shannow, but if the oil isn't flowing or rather being supplied in sufficient quantities to the parts of the engine that need it, lubrication will indeed suffer.
That's the entire purpose of CCS/MRV, to ensure proper flow/lubrication at the temperatures it is tested at. Above those temperatures, you are not sacrificing anything other than perhaps some additional power loss due to drag and the more viscous oil being harder to pump.
Running a grade heavier (without an appropriately higher VI) means the oil pump will
be in bypass more often every time the engine is started cold and you will also need to achieve 10-15C higher oil temp's befor you can use maximum rev's and still not be in bypass.
I'm just pointing out the downside of running a heavier oil grade, even one with the same SAE winter grade rating or even a lower one.
The oil pump possibly being in bypass is a detour. Many Chrysler engines are on the bypass all the time. That's the purpose of the bypass to ensure that sufficient pressure is maintained in the system and excess routed back into the pump or the sump.
Bypass operation, frequency and set point are all incredibly manufacturer specific and one cannot simply state that because the pump is bypassing that damage is being done.
Insufficient flow would be the result of using a lubricant not appropriate for the conditions, like the example I cited. Other than an extreme condition like that the oil will pump, the oil will flow and there will be adequate lubrication.
Will there be lost efficiency? Certainly, but this is the case with any lubricant below operating temperature. There will be more drag and fuel economy will be slightly affected.
The problem I am seeing here is that you are trying to use statements that would make sense in the context of a lubricant being discussed outside its designed operating range to further your high VI agenda and subsequently these statements become nonsensical because they lose the connection to what validates them.
VI has nothing to do with cold temperature performance; it is calculated from the 40C and 100C visc values and does not extrapolate below 0C. CCS and MRV are directly applicable to cold temperature performance because that's what they measure. They can be backwards extrapolated in 5C increments from their measured point to around -15C.
On top of that, the differences between the various CCS and MRV measurements are THOUSANDS of cP; absolutely MASSIVE differences between oil grades, whilst above 0C, we are talking 10s and sometimes 100s or so cSt between grades. Minuscule by comparison. Yet this is the data you have chosen to fixate on
