It has rust issues. There is about a quarter sized hole in it. I cleaned all the rust and dirt off of it and put some HVAC tape on it as a temporary repair to keep water out, but I am looking for suggestions for a permanent repair. Obviously the preferred method would involve welding. While I do have a welder that would probably work, I don't think I wend good enough for a rain-proof seal, and I don't see myself lugging the welder up to the roof on a ladder. It doesn't have to look pretty, and I probably need to go over a portions of the roof with something like POR-15, after wire wheeling it and priming, then paint the whole thing.
Any suggestions on sealing the hole? I'm thinking bolt on a piece of metal and use caulk to keep the water out.
