I have a '10 Maxima with aftermarket wheels with the OE TPMS sensors installed. When I changed out the wheels last week, I noticed one tire extremely low - and upon checking it was at 4 1/2 psi. We have a cold snap this week, and sure enough, that same tire had dropped from 37 psi to 29. I am sure about 4-5 psi of that was just temperature change, but that was enough to light the TPMS icon on the dash, and filling it turned off the light.
I inspected all the tires closely when transferring, so I know there are no punctures, etc. I also made sure the valve core was tight when filling last week. These tires have been on the wheels for about two years, so I doubt the issue is a bead/seating issue.
So my question is - can the valve cores just fail? If so, can I pick one up and change without losing the bead seal? Or should I just take it to a dealer?
