Fuel dilution, cylinder wash-down (which compromises the oil film at the ring-cylinder interface), excessive soot loading of the oil, and intake valve deposits*: these are you DI hobgoblins.
Based on owning an Audi DI engine and working closely with Terry Dyson to get an oil and fuel combination that mitigates these problems, it's pretty clear that motor oil for gas engines has not kept pace with the demands that DI engines place on the oil. In many ways, DI gas engines are harder on oil than diesel engines are, especially given the poor quality of domestically produced gasoline. In a DI engine, 10% ethanol in the blend is actually a true benefit in helping to alleviate some of the issues listed above.
As someone posted above, with any DI engines it's imperative to use a good quality synthetic and don't run it over 5000 miles. The best bet for optimum service is to do several UOAs and establish a good baseline for what is "normal" for your particular engine.
*Some DI engines are more prone to intake valve deposits than others. Audi's TFSI engines are the worst, with Hyundai a close second. On these engines the gunk can build up on the intake valves in as few as 30,000 miles to the point that driveability becomes an issue and the intake has to be pulled and the valves cleaned. GM and Porsche engines, on the other hand, seem to only exhibit a light ash-like deposit on the intake valves that does not affect driveability. Haven't read anything on Honda's DI engines.
