Originally Posted By: mjoekingz28
Originally Posted By: Booki
I am aware that we in AUS rarely have "freezing" temps, so oil weight is not something we have to worry about changing year round.
Was just wondering why some companies would recommend a 5w oil for a motor that is i guess "designed" with a 15w oil in mind.
Could running a oil too thin on the "W" rating cause any damage or increased wear?
It is MY understanding that the lower W number is better for winter, but not as good for summer.
Liken it to this, at a racetrack in the desert do you want a 0w-50 or a 20-w50?
Technically - I guess it wouldn't matter if the oil was at operating temp as they should be the same thickness/viscosity.
That said if u were going to beat on the engine cold, I don't know :\
