Originally Posted By: artbuc
I have Bridgestone Serentity Plus asymmetrical tires. After my 2nd rotation I had a hard pull to the left. I swapped front tires and the pull disappeared. I talked with Bridgestone and they were adamant that the pull could not be caused by the tire because if a tire causes a pull, it will pull whether it is on the left front or right front. I just had my alignment checked last week and it was dead on with right needing no adjustment and left needing minor but insignificant adjustment. Is Bridgestone right? Thanks.
artbic,
Swapping the tires left to right revealed you had both a tire problem AND an alignment problem.
Your realigmnent revealed the alignment issue - and that alignment issue might have permanently damaged the tire.
So you kind of have 2 poassibilities: Live with it until you replace the tires. Or replace the tires.
I did not have an alignment issue. The left tire was within spec (toe and camber) and he made a very slight adjustment just to bring it dead on. The right tire was dead on requiring nothing.
Just because an alignment machine says you don't have an alignment issue doesn't mean you don't have an alignment issue. My 97' Camry pulled to the right and the steering wheel was pointed to the left a little for the 12,000 miles I owned it. That was after the tie rods were replaced and 3 alignments were done. Also had 3 different pairs of tires up front and swapped all 3 left to right to see if that would fix the issue. It didn't. The last pair of tires were brand new too. It wore tires fine, but I just couldn't let go of the steering wheel on the highway for very long.
