Vehicle: 1998 Blazer 75k
The plan was to help my brother change the rear diff fluid in his blazer today since it is already on stands from the shock swap on Sunday, but after taking the diff cover off, it had no magnet. You can see where it once was though which is a plus I guess.. (I'll have to look in the folder the PO gave my brother to see when it was changed last..)
We had some Castrol synthetic 75w90 laying around that I was going to put in there, but now I am not so sure we should just yet assuming the internals could be a bit dirty even though visually they appear clean.
Walmart has a gallon of ST 80w90 for $12.xx. Would it be beneficial to run a few short intervals of this? By short intervals, I mean drive it 100 miles on the highway and do a drain and fill. I am hoping to be able to just siphon the fluid through the fill hole so I wouldn't have to mess with remaking the gasket(s).
(Not knocking ST branded products, but the the gear oil seems to leave something to be desired by many here on BITOG. Apparently a while back, it wasnt meeting the current gear oil spec??)
We ordered another magnet from the dealer btw. $12.
