Originally Posted By: Oil Changer
You fanboys sure stick together. You don't remember correctly. You realize that "IIRC" means IF I remember correctly. You don't. Nor were you there. Your argument is no stronger nor different than mine.
Your fondness for that slop has given you selective memory. It's called fanboyitis. No, I did not service it prior. The transmission was functioning perfectly and wasn't due for service yet. I wanted to get a jump on it before the cold weather set in. I followed the non-severe service schedule which means 100k. When I made the mistake of using MaxJunk, the perfectly functioning transmission was only at ~75k. The OP is still floating around. I'm not starting it over for the benefit of you two.
I now own a different vehicle with the 4L60E. With trepidation I have done a complete exchange then a separate pan drop/filter change. This time with AC Delco Dex VI. That was last December. Running robust.
Here we go with the "credibility" again. Credibility on an Internet forum. That's funny. I don't care what you or anyone else thinks. I shared my experience with that cheap slop. Take it or leave it. That applies to you too, kschachn. Most seem to get it. You two don't.
No. MaxLife is NOT that good.
Edited to add: Since you like facts, why don't you ask '302fanboy where he got that 99% figure, or does he get a pass being in your clique and all?
Originally Posted By: 3311
Let it go. You have no credibility if your still saying maxlife caused your tranny failure. Iirc it was a 4l60e and you had not serviced it before? A tranny well know to not be GM'S most robust.
Ill admit your transmission failure is what has me worried to do others.
First though, I can honestly think of only one person on this site that hates Valvoline and that is you. You have based your opinion off of your experience and that is wonderful, but I assure you, you are the only one here with those feelings. It seems [censored] near every Valvoline thread has you mentioning how horrible it is. I remember you even trolling on my Maxlife PS fluid thread. C' mon dude.
At 75k, I cant help but wonder something (non fluid related) went horribly wrong. Transmissions can fail. Wrong procedure perhaps?
