Originally Posted By: rationull
I really like the idea of this product but I've got a question about applications with pinch-weld jack points. If you want to lift all four corners of the car, then with this setup you'll jack up each corner individually and lower it onto the stand. Say you jack up the driver's side front first. When you move to the passenger side front and start lifting the car, won't the driver's side front pinch weld, sitting in the adapter, end up "rocking" and potentially getting bent or slightly dragged across the small load-bearing surface inside the adapter?
But how well does this work in practice on pinch welds?
You could mitigate this with a full set of stands by running around and lifting each corner an inch or two at a time. Then the angles would be too small to matter.
