On my S10, I fully flushed out the cooling system when I replaced the intake manifold gasket and replaced the original radiator (less than a year ago). I am using approx. 30% supertech all makes all model 70% distilled water. I went with that ratio because I live in Los Angeles, CA where it's 60 degrees in the dead of winter, no concern with freezing coolant. I took my truck up to Mammoth Lakes, CA where it's relatively colder than Los Angeles. The truck was parked for 2 days. In the morning of the 2nd day, I opened up the coolant reservoir cap to inspect the coolant and it was flowing like normal. I believe the temp over night was between 10 and 20 degrees. I started the truck and it runs with normal temps. So, my observation, the 30 coolant / 70 distilled water ratio works in non severe weather areas. FYI, I have Valvoline Nextgen 5W30 in the crankcase.
