My wife just got a new 2014 Lincoln Navigator. It's the first car we've had that is a flex fuel. I've done a bit of reading on here on the subject but didn't see much about running E85 in flex fuel engines particularly.
I know it gets less MPG but often sells for cheaper. If it's low enough to offset the lower MpG is there a reason not to run it?
If I do use it, any reason not to use regular also if situations change?
