If bearing clearance dictates the HTHS requirement of the oil,
an engine with tight bearing clearances could lose more power to
friction with 0W20 than an engine with lose bearing clearances
would with 20W50.
I read somewhere that oil shear rate and friction increases when bearing clearances decrease.
To improve economy, if the above is true, then engine bearing
clearances should be increased.
The drive for lower HTHS engine oils would not be to satisfy the bearing clearances, as they can be adjusted, but to lower the viscous drag on the cylinder walls.
If HTHS is the true grade of an engine oil, and it seems to be the most talked about specification, then the grading system can be simplified.
I like Shannow's post in the "new HDMO category" thread.
Example; 4.0/5W says it all.
"Operational viscosity" is never discussed except during the warm-up cycle, which may be a moot point.
would with 20W50.
