Originally Posted By: mjoekingz28
Z06, so in an emergency I would have to squeeze twice to get one round off? That is if I kept it on an empty cylinder.
I was thinking to have a full six in there and depending on a heavy pull as the safety. I had a shotgun that had a hair trigger, I don't want that in a revolver nor do I want to worry about dropping it, not that I wouldn't treat it as a 24kt gold bar.
I have a couple revolvers in the house for home protection. I keep them fully loaded and the hammer down - of course. In an emergency, you would simply point and squeeze the trigger to fire. That would be "double action" ... and the trigger squeeze would be longer and more effort, but not bad.
If you had time, you could cock the hammer and then squeeze the trigger, which would be a shorter and less effort trigger squeeze - that's known as "single action". Double action means with a trigger squeeze the hammer goes back and then falls ... therefore, there are two, or "double" action due to squeezing the trigger. Single action is when you cock the hammer back with your thumb, then pull the trigger to release the hammer - ie, a single action of the trigger due to pulling the trigger.
I believe any modern well known name brand revolver will have a trigger block mechanism design, so you wouldn't have to worry about dropping it and having it go off.
