Originally Posted By: aa1986
What about deionized RO water?
Also, I didn't think you could get deionized distilled water. Is there a difference between it and just distilled water?
I wouldn't. I know that many here will struggle to believe this, but I learned the hard way, that ultra pure water is very corrosive. Distilled water? Ok. DI water? Ok. RO water? OK. But I would avoid a combination.
In the test lab I used to run, we had a water purification system, for the water that was used in the salt fog corrosion chamber. The water first went through a carbon filter, then through two sediment filters. Next was a water softener. Then the water went through a set of DI tanks. After the DI tanks, there was another sediment filter, and lastly, an RO system.
Well, we decided that since this water was pure, it would be a good choice to use in the environmental humidity chamber. Pure water = less mineral buildup in the humidity generator, right?
What we ended up with is constant blown heater elements, and leaks in the system. The pure water was so corrosive that it would eat through the heater elements, and corrode the water lines.
The fix was to tap into the water before the RO. Problem fixed. No more blown heater elements. No more leaks. Environmental chamber ran like a champ after that.
So, count me as one to choose the simple, distilled water for mixing with coolant. But, if the choice were DI/RO treated water, or tap water, I'd go with the tap water.
