Pressure tested. Leaking from water pump, thermostat housing, and LIM. After removing the engine cover, the intake leak could be easily seen at the number 7 cylinder (rear, driver's side). All original parts.
Replaced all. Runs like new. Will change oil at 500 miles and re-sample.
