Originally Posted By: another Todd
There is more to it than just distance, you cannot compare two different vehicles that way. Vehicle weight (load), engine temps, ambient temps, engine tune, type for fuel metering, condition of engine etc all play a role.
Let's put it this way. If you drove your S-10 on the same trip only used a lower gear and did (for example) 3200 rpm at 75mph, then I would say the oil would degrade faster (per mile) at the higher rpm, but not because of the higher rpm, but instead because of a greater number of engine revolutions for the given trip.
That makes sense.
I'll take it a step further and say whichever trip burned the most fuel would be in the worst shape,regardless of rpm.
