Originally Posted By: wokeupdead
If the right wheel is moving by hand when jacked up, that condition needs to be rectified before alignment. There is unwanted toe change, and while you may be able to center the steering wheel, it will still not be quite correct, actually requiring more toe (probably) in on the right to achieve this. It appears he set the toe correctly, as the vehicle sat on his alignment rack at the time. I agree two inches is excessive. Self changing toe will prevent a good alignment. Loose bearings, bushings etc.
Thanks for your help. What started this whole problem is I replaced both ball joints on the right wheel last Saturday. The wheel does have movement when rocked at the 6 and 12:00 positions and I thought new ball joints would fix it. It is not as bad as before but is still a bit loose. I also thought the ball joints were the reason I had to prematurely replace a Moog wheel bearing on that wheel. The bearing only had about 6,000 miles on it. So I am trying my best to figure out what is wrong with the right front wheel/hub/axle and steering parts.
The guy at the tire store did not find anything wrong and did not come back and say he could not align it because of any problem with the front end. I have a lifetime alignment policy there so I can get it re-done when I find and fix whatever is causing the wheel slop and bad bearings. I did adjust the tie rods tonight, only moved the inners backwards about a quarter of an inch. Maybe that won't ruin the alignment. I did a test drive around my neighborhood and it seemed the wheel was more straight but it was hard to tell in the dark, even with the map light on. I will know more tomorrow. I will keep on until I find and fix the cause of the wheel problem. Any further help on this is greatly appreciated.
