Went to change my rotors and pads and already knew I had a stripped bolt on the caliper slide pin bolt, the passenger side front caliper bottom bolt.
I came prepared with a set of craftsman easy out sockets and new slide pins for both sides, but no matter how much I tried I couldn't get the socket to bite well enough without slipping off.
I could get it to bite some but when I applied torque it would eventually slip off. I even rounded it off more so I was able to get the smaller size easy out on it but still no dice.
What is the next best step when an easy out won't work?
Also while I had the car jacked up I noticed some possible worn suspension parts.
