Originally Posted By: Artem
Originally Posted By: Nate1979
Ridiculous. Maybe the Mobil engineers, you know the ones with the actual performance information on their oils, should check this thread out so they can make a better oil. Imagine the millions they could have saved by just getting a $20 VOA to design an oil......
Do you honestly think oil manufacturers produce and sell us the BEST they can manufacture? The reality is, they blend oil to give us the MINIMUM protection needed, to get the job done. The millions of cars on the road today simply don't need more.
Even with that in mind, engines will outlast the body of the car with regular oil changes.
You think oil manufacturers will sell us the top of the line blend for $25.99 at Walmart?!
If synthetic oil was the same, why would auto manufacturers specify a certain oil requirements just for their engines? Take BMW for example and their specs for oil.
Bottled oil is designed with a certain performance in mind. Mobil 1s EP line is designed with extended drains in mind. Another oil is designed for performance and doesn't care about extended drain additives. This is where blending a Caterham mix might just produce a strong blend as the end result.
You forgot to add IMO at the end of your post.
How many promoting blending here are prepared to offer a warranty to back up the performance of their blend ?.
What is promoted here may sound good, but in actual practice what has been blended is anyone's guess unless it is tested to some standard IMO.
Pure fantasy and guess work IMO. From what I read here should oil manufacturers should be queuing at Caterham's door waiting to buy the patent rights to for the blends.
