The ac in my windstar works fine going down the road, but blows warm when the car is idling at a stop.
I thought it would be a leak, but when I put the gauge on it, it has very high pressure - I think on the low pressure side, because it is the smaller fitting.
If the system is plugged with very high pressure, why would it work with increasing rpm's and/or vehicle speed. I did not check if the ac fan is working.
