Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
Castrol magnatec
by ChadW
06/25/16 04:07 PM
Purolator Red 14612 Weedeater Size 6k miles
by bbhero
06/25/16 04:05 PM
by bbhero
06/25/16 03:46 PM
2001 Chrysler Concorde selling for cheap.
by chryslerconcorde
06/25/16 03:24 PM
How to open please?
by dblshock
06/25/16 03:19 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
93 registered (4_Fun, ammolab, 901Memphis, abycat, 97f150, 8 invisible), 1708 Guests and 9 Spiders online.
58272 Members
66 Forums
250812 Topics
Page 2 of 5 < 1 2 3 4 5 >
#3460246 - 08/20/14 11:45 AM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
wsar10 Offline
Loc: PA
Originally Posted By: lukejo
I read that some HM oils are on the thicker end of the scale within grade. Is there a difference in thickness between these two HM oils (or VML for that matter) in 5w30?
between the oils in the OP, the PNZL is a BIT heavier....
you can verify his with the oils TDS in the links above.
98 JEEP ZJ, 5.2 T5,WIX
03 Jeep WJ, the famous 4.0 T6,WIX
93 Jeep XJ, the famous 4.0 T5, WIX
01 Dakota, 3.9l T5,WIX
07 Explorer, 4.0 GC 0-40,WIX
11 KIA
#3460289 - 08/20/14 12:19 PM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
CELICA_XX Offline
Loc: Oklahoma
Another vote for the Pennzoil HM... it completely stopped a leak in an old Accord I service.
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - PU 5w30 / KREEN experiment
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valvoline MaxLife Full Syn 5w30
#3460810 - 08/20/14 09:46 PM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
motorguy222 Offline
Loc: Ky
According to the Mobil Super HM bottle it is a full syn.
#3460919 - 08/21/14 02:53 AM Re: Pennzoil HM vs Mobil Super HM? [Re: motorguy222]
wemay Offline
Loc: South Florida
I only see blend, and even that is hard to find. Only seen on the back of the jug where they compare their own oils in a diagram. M1 HM is full syn, MS HM says blend.
16 Toyota Corolla LE 1.8L
13 Hyundai Santa Fe 2.0T
#3460960 - 08/21/14 06:13 AM Re: Pennzoil HM vs Mobil Super HM? [Re: wemay]
lukejo Offline
Loc: IL
Is there any indication that the P HM is a blend as well? Seems to me it is PYB with the addition of seal conditioners....which is fine, just curious as I compare/contrast these two.
#3460988 - 08/21/14 07:01 AM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
wemay Offline
Loc: South Florida
Yes, PHM is a great conventional.
#3461153 - 08/21/14 10:23 AM Re: Pennzoil HM vs Mobil Super HM? [Re: 147_Grain]
BlueOvalFitter Offline
Loc: Cajun Country, La.
Originally Posted By: 147_Grain
For comparison, here's some specs on Valvoline Maxlife's HM version:
http://www.valvoline.com/pdf/maxlife.pdf
I see the Noack % number is lower in the VML 5W30 than is in the 5W20. Isn't an oil with a lower Noack % number better for an engine? And, being it is a 5W30, wouldn't it suffice in an engine spec'd 5W20?
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#3461215 - 08/21/14 11:44 AM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
sshimp Offline
Loc: Lewisville TX
Them MS product is simply going to outperform the Penzoil. For a GOOD high mileage oil, consider Mobil 1 High Mileage.
If at first you don't succeed, well, that's it for skydiving!
#3461339 - 08/21/14 01:34 PM Re: Pennzoil HM vs Mobil Super HM? [Re: sshimp]
dave1251 Offline
Loc: Maricopa, AZ
Nope.
don't use.
#3461825 - 08/21/14 09:00 PM Re: Pennzoil HM vs Mobil Super HM? [Re: wemay]
motorguy222 Offline
Loc: Ky
I have been using the MSHM for some time and have some of the quart bottles and the say that it is a full syn. on the back in the comparison chart.
The qt. bottles are now a more silver color, more the color of the Mobil Super Synthetic instead of the more gray color they used to be.
The 5qt. jugs have also had a slight label change on the front and back both.
I have 5W-30,10W-30 and 10W-40 qt. bottles of the MSHM on hand(some empty) and they all say "Full Synthetic" on the back, I just checked to make sure.
#3461832 - 08/21/14 09:06 PM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
dave1251 Offline
Loc: Maricopa, AZ
don't use.
#3461863 - 08/21/14 09:32 PM Re: Pennzoil HM vs Mobil Super HM? [Re: dave1251]
motorguy222 Offline
Loc: Ky
I have the bottles, the website has not been updated.
Go to WM and look at the bottles. They are silver in color, not the darker gray.And since it is a full syn. the front and back labels have been changed.
The back label plainly says "Full Synthetic" under the MSHM bottle in the copmarison chart. I am holding one of the bottles in my hand right now.
The chart has a "Mobil Super" on the left, the "MSHM" in the middle and "Advanced Full Synthetic" on the right and the MSHM says Full Synthetic.
#3461864 - 08/21/14 09:32 PM Re: Pennzoil HM vs Mobil Super HM? [Re: dave1251]
babbittd Offline
Loc: Massachusetts
Yeah that's what I thought too.
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_Super_High_Mileage.aspx
Mobil Super High Mileage uses a combination of synthetic and conventional high quality base oils...
They could make the webpage that you linked to a heck of a lot more clear about this.
#3461868 - 08/21/14 09:38 PM Re: Pennzoil HM vs Mobil Super HM? [Re: babbittd]
motorguy222 Offline
Loc: Ky
The website has not been updated, I have the bottles.
#3461878 - 08/21/14 09:49 PM Re: Pennzoil HM vs Mobil Super HM? [Re: lukejo]
babbittd Offline
Loc: Massachusetts
I'm a little slow on the uptake, so motorguy222, what you're saying is that the Mobil Super High Mileage USED to be made from conventional only?
