Hi:
I drive a 2012 Tahoe at work, in narrow, dark areas. I clicked on your link but had some questions.
a. have you purchased from them?
b. bulb shows both 50w and 60w, depending on place in web.
c. I can't get Tahoe to come up, but I think 3157? not T-10.
D. Can I assume 60w is close to oem but the 9-1100 lumens is much higher?
e. if useable I will buy and maybe use just 1 on right, as it is a big deal at work if even a small dent. I think 1 screw in side from open rear hatch to pull assembly out?
f. $16.95 is an ok range if reliable and fits / works / improves.
Thanks.
Thanks.
