i've heard about this practice as well
on an unrelated note, after you fill the crankcase with oil, is it a requirement to turn on the engine and let it idle as many oil change instructions tell you or could you just drain the oil, then fill it and not turn the engine on until you have to? if so, how long should you idle the engine for after pouring in fresh oil and is this required or optional?
