2011 BMW 335xi 6111mi M1 0w-40 -potassium gone?-
by 89Rustang
07/28/16 10:21 AM
15" Wheels on Lots of New VW Cars in Showroom
by Boomer
07/28/16 10:14 AM
2006 Volvo V50 Wagon, reliable?
by pandus13
07/28/16 09:47 AM
02 Protege oil consumption
by smetzger
07/28/16 09:31 AM
Misspelling
by callbay
07/28/16 09:21 AM
Suggest an experiment?
by ToadU
07/28/16 08:39 AM
FCA to produce no *cars* in the US
by Hokiefyd
07/28/16 08:37 AM
Zero Emission Power Stations...
by Shannow
07/28/16 05:52 AM
200k!!!! 2005 legacy gt wagon manual transmission
by madRiver
07/28/16 05:38 AM
Adhesive protective patch in wheelwell
by dlundblad
07/28/16 05:02 AM
My Faith Has Been Restored
by bobbob
07/28/16 02:57 AM
Kohler Courage 15
by Commeres
07/28/16 02:13 AM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
79 registered (2015_PSD, Astro14, aircooled, Al, 97 GTP, 3 invisible), 1838 Guests and 10 Spiders online.
58627 Members
66 Forums
252351 Topics
#3444572 - 08/03/14 09:42 AM NAPA Gold 7899 (Chrysler) vs 1372 (Ford)
Bookmaker Offline
Loc: Virginia, USA
So according to the following NAPA memo from 2008:
NAPA memo
NAPA makes separate filters for Chrysler and Ford applications due to the different pitch of the 22mm threads on the Chrysler engines.
So why then do other manufacturers specify the same filter for both Chrysler and Ford applications?
The NAPA filters in question cross reference to the Fram XG2, Bosch 3410, etc., which are listed for both Ford and Chrysler applications. If you go to Rockauto.com it lists the Wix 57899 and MC FL-820S for my 2013 Dodge 5.7 Hemi. Then Rockauto.com lists the MC FL-820s and Wix 53172 for a 2008 Mustang 4.6L.
So WIX/NAPA states different filter applications between Chrysler and Ford, but everyone else says they are the same.
Does anyone know why this is?
#3444588 - 08/03/14 10:02 AM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Bookmaker]
Texan4Life Offline
Loc: Texas
interesting..
22X1.5-6-H MM
22X1.5 MM
I think I might need to look up what the difference actually is.
what does the -6-H designate?
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#3444594 - 08/03/14 10:09 AM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Bookmaker]
Texan4Life Offline
Loc: Texas
ok here is the skinny... They are both the same thread... just the mopar specifies a thread tolerance class of 6H
#3444664 - 08/03/14 11:46 AM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Bookmaker]
Bookmaker Offline
Loc: Virginia, USA
So it's safe then to use a NAPA 1372 or MC-820s on Mopar?
#3444757 - 08/03/14 01:53 PM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Texan4Life]
ZeeOSix Offline
Loc: PNW
+1 ... it's just tolerance of the cut thread profile. You can have the same thread dia and pitch, but can cut the threads so they screw together loose of tight, depending on exactly how the profile of the threads are cut.
A filter's brand name doesn't matter ... what's inside does.
#3444761 - 08/03/14 01:57 PM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Bookmaker]
ZeeOSix Offline
Loc: PNW
If they are both 22mm dia x 1.5 mm pitch, then I'd say they will all screw on fine. A little bit of thread profile difference isn't going to make or break the fit IMO. That's why others show them both cross referencing as applicable filters.
#3444780 - 08/03/14 02:30 PM Re: NAPA Gold 7899 (Chrysler) vs 1372 (Ford) [Re: Bookmaker]
Bookmaker Offline
Loc: Virginia, USA
Though I had no trouble from the Bosch D+ filters I used on my Hemi, I think it speaks well for Wix that they are the only manufacturer that took this OEM spec seriously enough to produce a special filter for it.
