Air filter wrap
by Duffyjr
57 minutes 43 seconds ago
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
Today at 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
Today at 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
Today at 09:34 PM
Choose for me
by Duffyjr
Today at 09:26 PM
Help w/Transmission Drain & Fill
by klt1986
Today at 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
Today at 08:10 PM
Group 5 synthetic oil
by Brayden
Today at 08:07 PM
Ultra
by RubentheIowan
Today at 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
Today at 08:03 PM
CEL Code P2097, 2010 Mazda 6 with 2.5L I-4
by Snyperx
Today at 08:01 PM
Laser scope on a Henry .22?
by Chris142
Today at 07:58 PM
Spinnizle, JustinL, abdoezzat, JanK, paydase
57755 Registered Users
74 registered (AntsinmyEyes, barkingspider, 901Memphis, AirgunSavant, 2015_PSD, 7 invisible), 1231 Guests and 257 Spiders online.
57755 Members
66 Forums
248280 Topics
Page 1 of 3 1 2 3 >
#3439012 - 07/28/14 09:41 PM 14' JGC with the pentastar 3.6L
subaroo Offline
Loc: iowa
specs 5w20...does anybody have some knowledge on this engine. would I be safe running 0w20? manual just specs 5w20.. is this v6 hard on oil?
2012 Suburu Outback 2.5i Caterham Blend Napa Gold 7055
2014 Jeep Grand Cherokee Limited 3.6L PYB 5w20 oem filter
#3439016 - 07/28/14 09:47 PM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
sicko Offline
Loc: Virginia
I'm not aware of any 5w-20 that can't take a 0w-20.
The 0w just means it doesn't get as thick as the 5w when very cold, (which is a good thing).
#3439028 - 07/28/14 10:06 PM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
Kuato Offline
Loc: In transit...
0w20 good to go....
You like what you like.
Amsoil
13 F150, 5.0, 78000km (48k mi)
04 Wrangler, 2.4, 312000km (194k mi)
#3439082 - 07/28/14 11:07 PM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
SEMI_287 Online   sleepy
Loc: Up State NY
Run a MS-6395 oil while in warranty. No 0w20 carries that spec that I'm aware of, unfortunately.
2007 Chrysler 300C- M1 5w20 Wix filter
2014 Dodge Avenger- M1 AFE 0w20 M1 filter
2008 Mitsubishi Galant- PU SM 10w30 Wix filter
#3439176 - 07/29/14 04:16 AM Re: 14' JGC with the pentastar 3.6L [Re: SEMI_287]
demarpaint Offline
Loc: NY
That is correct. IIRC none of the Mobil products meet the spec either.
God Bless Our Troops
#3439212 - 07/29/14 06:28 AM Re: 14' JGC with the pentastar 3.6L [Re: SEMI_287]
Danno Offline
Loc: Northern Ontario, Canada
This +1
#3439213 - 07/29/14 06:31 AM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
KD0AXS Online   content
Loc: Nowthen, MN
Apparently Valvoline Synpower 0W-20 meets MS-6395.
http://www.valvoline.com/pdf/synpower.pdf
2014 Hyundai Elantra Coupe 2.0 GDI-PUP 0W-40
2013 Jeep Wrangler JKU-PUP 5W-20
2005 Ford F-350 4x4 5.4-Maxlife 5W-20
2000 John Deere 425-Rotella T6
#3439238 - 07/29/14 07:22 AM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
glock19 Offline
Loc: Virginia
QSUD and PP meet MS-6395. Either of those in 5w-20 would keep your warranty intact.
2015 Subaru Outback Premium - 14k mi - His
2010 Toyota Highlander Limited - 190k mi - Hers
#3439308 - 07/29/14 08:56 AM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
JTK Offline
Loc: Buffalo, NY
If "MS-6395" 5w20 is readily available for you, why not use it. If not, I certainly wouldn't sweat it. I've yet to hear of a lubrication related issue with a Pentastar, or any warranty concern where this particular oil spec was brought up.
I have no idea for sure, but most Dode/Chrysler/Jeep dealer bulk oil tanks, or what ever Kwiki-Loob you might choose probably don't contain the stuff anyway.
FWIW, I run Napa full synthetic 5w20 in my 2013's Pentastar. Like said, 0w20 will be a similar oil at operating temp, and will be a better cold-start oil. The last thing I'd worry about is the MS-6395 thing.
Edited by JTK (07/29/14 08:57 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#3439338 - 07/29/14 09:38 AM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
wymi516 Offline
Loc: Illinois
I use QSUD 5w-20 and an oe filter in our 2014 200s with the 3.6L motor. The 3.6L motor runs great and is very quiet. No oil consumption at all between changes and I just use the OLM.
2013 Mazda3 iTouring 2.0L DI M1 0-20 OE Filter
2013 Chevy Impala 3.6L DI M1 0-30 OE Filter
2014 Chrysler 200S 3.6L PFI M1 0-20 OE Filter
#3439391 - 07/29/14 10:35 AM Re: 14' JGC with the pentastar 3.6L [Re: JTK]
subaroo Offline
Loc: iowa
Yeah, your probably right the salesman was showing us their oil/filter rates and had a picture of a kendall bottle on it.
#3439489 - 07/29/14 12:31 PM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
Kuato Offline
Loc: In transit...
As usual, bitogers are not answering OP's question, which was "is it safe to run 0w20". The question was NOT "is there a 0w20 that meets Chrysler specification", or "will I have warranty issues using 0w20".
The answer is: yes your engine will be safe on 0w20.
It is common courtesy to answer a question before discussing the ramifications.
Have some courtesy people.
Amsoil
#3439495 - 07/29/14 12:35 PM Re: 14' JGC with the pentastar 3.6L [Re: subaroo]
yvon_la Offline
Loc: quebec canada
If it meet chrysler requirement?use it
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3439509 - 07/29/14 12:48 PM Re: 14' JGC with the pentastar 3.6L [Re: demarpaint]
beadvised Offline
Loc: Tennessee
BE ADVISED this information is FALSE. Mobil 1 doesn't meet the MS-6395 SPEC. MS5K DOES MEET THE MS-6395. Run PYB or PP 5w20 and forget about it. Use with confidence and sleep well at night.
#3439577 - 07/29/14 02:13 PM Re: 14' JGC with the pentastar 3.6L [Re: Kuato]
glock19 Offline
Loc: Virginia
I guess that depends on what you consider safe. If I were asking for an oil recommendation on a brand new vehicle I would only consider oils that won't void my warranty as safe.
He asked people's OPINIONS on whether it would be safe. Most people here recognize that the people that know his engine best are the engineers who built it. They said use 5w-20 so we're echoing their recommendation. You shouldn't jump down people's throats for trying to help him out.
Page 1 of 3 1 2 3 >
