Originally Posted By: AvoidTheNoid
Thanks for all the input. I am running some MMO now to see if I can clean things up maybe unclog those holes, I just don't want to go crazy with additives and the like.
I will keep trying different HM oils on sale until I find the one which consumes the least. I'm thinking about QS Defy next time considering it isn't SN rated as my car is SJ rated so maybe that will help. I've tried Castrol HM, Havoline HM, now VML, so that leaves Pennzoil, Quaker State, and Mobil.
I think I'll go from 5000 to 7500 miles, I've been changing oil every 6 weeks so a break from that is decent. A buddy recommended Mobil 1 HM, maybe when I get some coupons or rebates I'll try it.
My Pilot gets synthetic but doesn't burn a drop between 7500 miles so obviously a big difference.
As far as the transmission, I do change the fluid, its the 3 speed auto, shifts fine.
All around the car is solid no leaks under the car, no strange noises, plenty of acceleration. I changed the plugs, coolant, got a new battery. My only concern is the oil burning, but I've also heard anything less than a quart per 1000 miles isn't too bad.
After I work my way through the high mileage oils I'll go to the heavy duty ones and see if that works.
Thanks for all the quick replies.
I don't wanna spend your money, but I did have some luck with Mobil 1 HM cleaning out an older engine a bit and reducing consumption, but that's rolling the dice a bit with a few bucks. Mobil 1 is on "rollback" right now for $23 a jug, so maybe a couple 5K OCI's to see if it does something to reduce consumption with some cleaning might not hurt, but that will be a bit more money than using the cheapest oil on sale...
