Safety violation? who knows...
by CourierDriver
08/24/16 06:14 AM
82 Yamaha Virago 750 engine oil
by Trigger
08/24/16 06:02 AM
Supercheap Auto Father's Day Version 2 sale
by KL31
08/24/16 05:39 AM
$4 Off Fram Oil and Air Filter Combo
by Tony_Mack
08/24/16 05:37 AM
U joints
by dlundblad
08/24/16 04:41 AM
Yamaha Bolt XV950
by FWR132
08/24/16 02:12 AM
Mower revs up/down when cold
by DrRoughneck
08/24/16 12:14 AM
2015 dodge journey crossroad
by hardcore302
08/23/16 10:17 PM
Looking for new mechanical pencil
by Merkava_4
08/23/16 09:33 PM
Sewer gasses in bathroom
by sxg6
08/23/16 09:13 PM
I am a idiot, a fool or what? UOA coming soon!
by Vern_in_IL
08/23/16 08:57 PM
4ft LED T8 replacement bulbs 6.97$
by Rand
08/23/16 08:35 PM
Bigford545, FWR132, smancer, FJCurious, kburns
58899 Registered Users
58 registered (alarmguy, 04SE, 09_GXP, baitbuster, Bandito440, 2009Edge, 7 invisible), 1029 Guests and 10 Spiders online.
58899 Members
66 Forums
253481 Topics
Page 1 of 2 1 2 >
#3429116 - 07/19/14 08:41 AM 85w140 Oil Helped a bit with Vibrations?
Miller88 Offline
Loc: Onondaga County
I have been chasing driveline vibrations for 2 years on the cherokee.
Finally decided to do SYE this spring. Driveline angles were set properly with shims on the axle. I still had vibrations. Then, I decided to bring the double cardan driveshaft to fleetpride to have it rebuilt and balanced. They did all of thta.
Still had problems.
I noticed that if I would drive for extended periods of time, they would "creep" down slower and slower. IE - on the way into work in the morning, I could go 55 with no problems. But on an extended highway run, I would have problems with 45 by the time I got to my destination.
I decided to dump in some 85w-140 oil to see if that helped.
Oddly enough, It seemed to help a bit. I can now run 65/70 with minor vibrations. Last night I drove it at 70 for probably 15 or so miles and the vibrations didn't get to the point I thought I was going to get an inner ear infection or have something let go.
Guess my rear end is toast. Apparently something is so worn out that the 80-90 would get too "thin".
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3429130 - 07/19/14 09:02 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Doog Offline
Loc: North Coast
Try putting a microphone on the rear diff and driving on the freeway. That might give you a better indication if you have an issue with the diff.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
#3429136 - 07/19/14 09:10 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Rand Offline
Loc: NE,Ohio
might be a good time to upgrade to a 8.8 from a ford exploder.
Edited by Rand (07/19/14 09:10 AM)
2015 Forester I-Premium 6MT
#3429152 - 07/19/14 09:32 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
NHGUY Offline
Loc: USA
The Chrysler 8-1/4 and Dana 35 is well known for bearing/gear failures.Parts stores sell a ton of Cherokee/Grand Cherokee bearings/seals due to the problems they have.
#3429573 - 07/19/14 08:11 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Miller88 Offline
Interesting. I'll have to try that!
I'm trying to figure out how to make that work. They are somewhat readily available in 4.10s. All I would need to do is weld on some leaf spring perches and upgrade the parking brake cables and brake proportioning valve to get it under there. Viable option as I can get a good 8.8 for $100.
The only downside is the 8.8 is a bit narrower than the 8.25'' axle.
The Dana 35 is a pretty bad rear end - not just pinion bearings.
This 8.25 has always howled on deceleratin. I have a 6* shim in the back and I ran it low on oil for an unknown amount of time. I checked it back in May (for the first time ever) and it only had 1/2 quart in it (full capacity is 2.2 quarts). My guess is not only did it starve the pinion bearing but lots of other things.
#3429627 - 07/19/14 09:11 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
artificialist Offline
Loc: Florida
I'm glad you were able to quiet it down with just oil, because my dad knew some people who had to fill the rearend with grease because of a lousy design.
2010 Lancer Ralliart Sportback
#3429683 - 07/19/14 10:16 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: artificialist]
Miller88 Offline
That may need to come next! I need this to hold out another 6 or 7 months.
#3429754 - 07/19/14 11:35 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Greasymechtech Offline
Loc: Paradise of Florida
Amsoil SAE 190 or 250
Torso SAE 250
Lucas SAE 250
Go thick typically means that it's broken
At what point should a lurker start posting :-)
#3429953 - 07/20/14 08:39 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Miller88 Offline
I'm doing the equivalent of putting 20w-50 in an engine because it has low oil pressure and knocks ...
#3430092 - 07/20/14 11:10 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
andyd Offline
Loc: Marshfield , MA
Heh heh, 80/90 was keeping the rods attached on my first car. I was 10 and the car was a 53 Ford I paid 5$ for. grin2
PS, my 528e owner's manual suggests 20w50 for my temperature range. It does the job quite well.
Edited by andyd (07/20/14 11:15 AM)
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3430115 - 07/20/14 11:41 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
MolaKule Offline
Loc: Iowegia - USA
"double cardan driveshaft "
Are you referring to an actual vibration that seems to run and up and down the driveshaft, or a noise that is coming from the differential?
Are the U-joints "phased" properly?
"Never buy flowers from a monk; only YOU can prevent florist friars." Smokey smile
#3430427 - 07/20/14 05:42 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: MolaKule]
Miller88 Offline
It's coming from something either in the driveshaft or rear end. It goes away when I remove the driveshaft.
The same was true when the pinion bearing failed in the front differential. Wasn't the driveshaft, but problem would go away when the driveshaft was out.
U Joints are phased properly.
#3430785 - 07/20/14 11:28 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
MolaKule Offline
Loc: Iowegia - USA
If there is any wet areas around the drive pinion bearing seal you most likely have 1.) a drive pinion bearing going out.
Other possibilities are 2.) a chipped or missing tooth on the drive pinion gear or the ring gear, or 3.) an axle bearing.
Usually it's 1.
Edited by MolaKule (07/20/14 11:30 PM)
#3430895 - 07/21/14 07:47 AM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Miller88 Offline
This seems to be eerily similar to what happened in the front. Seeping oil through the pinion (yes, I'm a dumb --- for not checking the leaking differential for two years) and vibrations. Eventually they got worse and I could wiggle the pinion yoke around.
The 80w-90 seeps through the pinion. The 85w140 does not ... yet.
This particular rear axle is known for pinion bearing failure.
It's going to get expensive, that's for sure. I'm not going to pay the labor to have a new pinion bearing put in and end up with 3.55 gears; if I am paying for that labor it's getting lower gears. Which, of course, means the front needs it as well.
#3431570 - 07/21/14 07:54 PM Re: 85w140 Oil Helped a bit with Vibrations? [Re: Miller88]
Loc: Florida
Did the vehicle have a factory option for 3.55 gears? If so, getting a good 3.55 gear front differential may be a cheaper and simpler option.
Page 1 of 2 1 2 >
