Any machinists?
by NavyVet88
7 minutes 59 seconds ago
new XG750R flat-tracker
by Mik
41 minutes 7 seconds ago
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
44 minutes 54 seconds ago
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
Today at 08:07 AM
Real Estate Rates
by AirgunSavant
Today at 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
Today at 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
Today at 03:48 AM
new castrol edge high mileage synthetic
by hiflo
Today at 03:32 AM
Just an interesting question
by southernjeeper
Today at 01:52 AM
Value power Walmart battery acid flying out
by bbhero
Today at 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
Yesterday at 10:35 PM
Steak-House Burgers
by sleddriver
Yesterday at 09:53 PM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
84 registered (2015_PSD, AirgunSavant, Atesz792, 4WD, ARCOgraphite, 8 invisible), 1673 Guests and 339 Spiders online.
57990 Members
66 Forums
249420 Topics
Page 2 of 2 < 1 2
#3418217 - 07/08/14 12:52 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
Of course hoses have been checked and so on. I am going to change the coolant though. I think its overdue.
#3418255 - 07/08/14 01:20 PM Re: 95+ degree travel [Re: opus]
440Magnum Offline
Loc: Texas
A 30-weight (5w30, 10w30) is adequate for a smallblock Chevy in any ambient temperature, providing everything is in good shape and it isn't needing to "band-aid" a problem like worn bearings or a weak oil pump. 10w40 is already overkill, no need for anything else. Especially Lucas Mucus, which can lead to foaming problems.
When operating in high ambient temnps (and 95-100 isn't what I'd consider "high" at all) its most important to focus on the cooling system- belts, hoses, radiator clean (both air and coolant passages), coolant condition, radiator cap, fan(s), and overflow tank, etc.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3418297 - 07/08/14 01:44 PM Re: 95+ degree travel [Re: opus]
chrisri Offline
Loc: Fiume, EU
Check your battery.If it's old it could let you down in that heat.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
#3418357 - 07/08/14 02:25 PM Re: 95+ degree travel [Re: opus]
Vikas Online   content
Loc: NorthEast
Does Lucas make anything for the cooling system? If yes, add it. That way you will *feel* comfortable.
#3418394 - 07/08/14 02:56 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
LOL, all is good. Just changing the coolant now and I'll call it good.
[Mental note; next time remove thermostat to speed process].
#3418407 - 07/08/14 03:06 PM Re: 95+ degree travel [Re: opus]
Turk Offline
Loc: MN
If it's overdue, yes, change it. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3418554 - 07/08/14 05:30 PM Re: 95+ degree travel [Re: opus]
Loc: NorthEast
And make sure you bleed the system properly otherwise you will have more problems than if you leave the coolant alone.
#3418623 - 07/08/14 06:24 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
We'd always park back end in a ditch and raise the engine to get the air bubbles out. smile
#3418845 - 07/08/14 08:57 PM Re: 95+ degree travel [Re: opus]
Oil_Flunky Offline
Loc: Michigan
Any weak tires like to blow out when it gets real hot. Make sure the spare is inflated, and your jack is serviceable with all the parts there.
Oil, you need it. Oil snobbery, you don't need it.
#3418915 - 07/08/14 09:40 PM Re: 95+ degree travel [Re: opus]
gman2304 Offline
Loc: n.c.
We all sound like mother hens....just go...and be safe, don't speed, take plenty of clean underwear, send us a post card, and let us know how your oil performed when you get back. geez!
#3418922 - 07/08/14 09:48 PM Re: 95+ degree travel [Re: opus]
opus Offline
Loc: Montana
No kidding geeeee....
Its all good. For all anyone knows I'm a 20 year old kid thats never turned a wrench. I dont even remember being 20! Just wanted everyones take on it.
#3419137 - 07/09/14 03:34 AM Re: 95+ degree travel [Re: opus]
Turk Offline
Loc: MN
Well, at least change the Coolant, "as you said it's overdue"....
That makes sense. Unless people don't make sense anymore...
#3427046 - 07/16/14 10:41 PM Re: 95+ degree travel [Re: Oil Changer]
another Todd Offline
Loc: Southern CA
Originally Posted By: Oil Changer
You will be fine with the 10W-40. If you're itchin' to change the oil before the trip, your choices are almost limitless. SAE 30 or 40, an HDEO 10W-30 like Rotella T5 or Delo. 5 or 15W40 HDEO, an HM 10W30 or 40...like I said, endless. Skip the Lucas. That's what I think.
If you are worried I would suggest the HDEO 15-40. Delo 400LE is less than 12 bucks a gallon at Walmart's around here and it is a very robust oil, as are the other HDEO oils.
2015 Ford F250 Diesel Crew Cab FX4
2005 Ford Focus ZX4
2007 Ford Focus ZX4
2005 Ford Escape
2006 Ford Escape
Page 2 of 2 < 1 2
