Citgo Supergard 0W-16
by addyguy
06/29/16 08:06 PM
MolaBrew
by synman
06/29/16 07:27 PM
Honda tensioner
by greasegunn
06/29/16 07:00 PM
Car&Driver opinion on Toyota weird styling
by HTSS_TR
06/29/16 06:01 PM
Old house woes
by OVERKILL
06/29/16 05:55 PM
Toyota Factory Fill???
by Doog
06/29/16 05:43 PM
Time to Replace?
by GMFan
06/29/16 05:20 PM
typical "life" of differential oil?
by TexasTea
06/29/16 04:22 PM
MaxLife Semi Syn 5w-20 vs Castrol HM
by dpaldino
06/29/16 04:10 PM
Vehicles with American contends are shrinking !
by HTSS_TR
06/29/16 04:03 PM
Anybody use Shell Rotella T1 SAE 40 in boats?
by Bgallagher
06/29/16 03:00 PM
"Scrub Radius"
by George Bynum
06/29/16 02:36 PM
jameson223, graywolf001, Likeapogi, 40fordcoupe, stickrpg23
58319 Registered Users
100 registered (alex_at, addyguy, alcyon, 5wleeb, Al, 12 invisible), 1875 Guests and 10 Spiders online.
58319 Members
66 Forums
250998 Topics
Page 2 of 2 < 1 2
#3412741 - 07/02/14 05:03 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
OVERKILL Offline
Loc: Ontario, Canada
Assuming your "plug in gauge" noted in the OP is in fact a reliable mechanical oil pressure gauge and not an electric gauge of some sort that leverages the factory sending unit I would indeed agree that you have a worn bottom-end, likely rod bearings, which tend to wear-out before the mains do in most engines that I have experience with.
If this is the case you can't really do anything about it without a tear-down or at least a partial tear-down. You could roll-in new main and rod bearings assuming the journals are OK, but of course that requires inspection, which will of course require a partial tear-down.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3416868 - 07/07/14 07:49 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
rc84 Offline
Loc: France
Hi,
Many thanks for all the replies.
Yes by 'plug-in' guage I meant a mechanical pressure guage. I do not know how accurate it is but it is new and a reputable brand, so maybe a bit off but not too much.
I will replace the coolant / thermostat / sensor, check & clean the EGR values and check & clean the oil cooler etc. in case this brings down the temperature. But tending to agree with everyone that it sounds like main bearings .. gulp.
If anything positive will post back.
Thanks
Russell
#3417112 - 07/07/14 12:15 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
yvon_la Offline
Loc: quebec canada
Remove oil pan and check oil pickup area for issue .if it isnt bent or clogged ?replace the oil pump
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3425494 - 07/15/14 01:00 PM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
Greasymechtech Offline
Loc: Paradise of Florida
Step up to a 0w40 or 5w40 full synthetic oil.
At what point should a lurker start posting :-)
#3426134 - 07/16/14 03:14 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
riggaz Offline
Loc: England
According to my data system on that engine you should have between 2.3 - 3.7 bar @ 2000 rpm (hot) so you obviously have a pressure issue, something in the oil circuit is definitely worn.
If there are no noises coming from the engine then I'd be looking towards the oil pump.
Edited by riggaz (07/16/14 03:16 AM)
#3426145 - 07/16/14 04:16 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
chrisri Offline
Loc: Fiume, EU
Does your car run with DPF? If not switch to ACEA A3/B4 5w40 oil and you will gain oil pressure. If however your car have DPF then use C3 5w40 oil. This is a low saps oil but with a minimum HTHS viscosity of 3.5 mPa.s and are superior to a A5/B5 oils.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
#3426189 - 07/16/14 06:25 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
yvon_la Offline
Loc: quebec canada
Oil filter plugging up!same thing happen on cummins isx.put a bigger version of oil filter
Truck driver
#3426190 - 07/16/14 06:26 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
yvon_la Offline
Loc: quebec canada
That sooth and particulate come from the oil.might want to change oil brand .
Truck driver
#3426202 - 07/16/14 06:40 AM Re: Oil Pressure Question ... is my engine dead? [Re: rc84]
SHOZ Offline
Loc: Illinois
This is common on the Ford Taurus SHO V6 Yamaha motors after 100k or so. They usually just drop the oil pan and change out the rod bearings. The oil pump is hi flow low pressure so any wear and the idle pressure drops when hot. I did mine in the driveway in about 4 hours. Found one of the bearings cracked. The Main bearings are usually OK and seldom changed.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#3426651 - 07/16/14 03:46 PM Re: Oil Pressure Question ... is my engine dead? [Re: Chris142]
Rollins Offline
Loc: Europe
Hello,
It seems that you have the infamous DV6 engine .
When the injector seals go south hot gasses from the cylinder make their way to the valve timing area (no gasket between the cylinder head and its upper part ...just some silicone !)
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=685547
You can imagine the result ...
http://www.theturboguy.com/uploads/1/0/3/5/10358883/api-presentation_1.6_hdi_carbon_issues-3-2.pdf
http://images.forum-auto.com/mesimages/511236/Fuitejointsdinjecteursexplication.jpg
Usually injector seals failure manufests itself with with some gas/oil leak around the injectors(lifting the plastic cover at least once a month is a must here).The sooner you catch the problem the better.
Althought this may not be the case here, I'd have it inspected ( dropping the oil pan-preferabley- or removing the vacuum pump would tell if there was any deposits)...
There is plenty of info about this design flaw affecting severals brands using this engine...
Why was the oil pickup replaced anyway? I hope it was not an attempt to get rid of the deposits caused by injector seals failure...it would take greater efforts to do the job.
#3442579 - 08/01/14 08:22 AM Re: Oil Pressure Question ... is my engine dead? [Re: Rollins]
riggaz Offline
Loc: England
I'm not sure it would cause his low oil pressure directly but excessive carbon/sludge deposits could have caused excessive wear, I think his turbo would have failed before any oil pressure issues arose though.
If you have one of these HDi engines it's always best to just change the injector seals out as a service item, apparently number 3 is usually the one that fails.
The Volvo lads say that the fault is not so epidemic as it is in the PSA/Ford cars, wonder what oil Volvo are using and whether that has anything to do with it.
Page 2 of 2 < 1 2
