Originally Posted By: yvon_la
Usually best method is to change oil more often and change main brand .till you have use 3 .like first 1000 mille you use mobil .second thousand mille you use penzoil and last thousand mille you use castrol.this should clean your engine .
Here we go, yvon strikes again... Would you care to provide us with some evidence that switching brands every 1k is "the best method" for cleaning your engine?
OP, sorry I do not have much to contribute. But I do not want you receiving false information. I do feel that a couple of short ocis would help though (short=~3,000 miles. Not 1k). Not pushing a brand, but an oil like Valvoline Maxlife (lots of detergents) should work well.
