This weekend I had stuff going on, and was running seemingly late for all of it, so I gave in and did what I've been wanting to do for a while: drive my truck like how I'd drive my car. You know, like at the speed limit (instead of trying to milk out every tenth of an mpg).
Before, for temps under 80F ambient, engine temp (off the Scangauge) indicated 180-185F, give or take, and 190-191 above 80F ambient. Now at 70mph it sits at 190-191 even at 60F ambient. No major surprise, engine works harder, and the thermostat does not have 0.1% load regulation.
The ATF reading I thought was more interesting. I'm 90% sure I have convertor outlet on the SG, the other temp sensor refuses to be read by the SG; the reading I get will drop in temp after convertor lockup within seconds. Again, at 60mph it will take forever to get up to 180F, and it will stay usually below water temp. But, at 70mph, even if it stays locked up for long periods of time, it will run a couple degrees warmer than water temp, like 194F.
I'm guessing that is from line pressure regulation in the transmission? Input shaft speed is higher, pump output is higher, but since x psi is still needed, it is just wasting that extra flow, hence warmer temp? I'm going from engine rpm of 1,500rpm to 1,900 or 2,000rpm, give or take a few mph.
[I'm not concerned, I just didn't think at 10mph speed increase would lead to a 10F trans temp increase. I don't know what temp the thermostat on the trans cooler operates at.]
