I'm looking to get new tires for the Pajero/Montero (265/70R16 112H) and I've narrowed it down to these two. I've had 3 sets of Pirellis so far, and they're pretty good tires. The only issue I have with them is dry rot, but that doesn't bother me too much, because I replace them every 3 years due to local weather conditions and UV. I'm tied between going for the Pirellis again or trying something new this time round.
Both tires are 265/70R16 112H. Here's the 411 on the Pirelli:
UTQG Data: 520 A A
Max Load: 2469 lbs.
Max Inflation Pressure: 44 psi
Tread Depth: 11/32"
Tire Weight: 40 lbs.
Rim Width Range: 7-9"
Meas. Rim Width: 8"
Section Width: 10.9"
Tread Width: 8.9"
Overall Diameter: 30.7"
Revs Per Mile: 678
Country of Origin: Brazil/Romania/UK
Low Rolling Resistance: N/A
And the Michelin:
UTQG Data: 440 A A
Max Load: 2245 lbs.
Max Inflation Pressure: 51 psi
Tread Depth: 10.5/32"
Tire Weight: 37 lbs.
Meas. Rim Width: 8"
Section Width: 10.7"
Tread Width: 8.7"
Overall Diameter: 30.6"
Revs Per Mile: 679
Country of Origin: Poland/France
Low Rolling Resistance: Green X
So they're pretty much on par, price wise as well. I'm just wondering if there's anything that makes one better than the other. Thanks.
UTQG Data: 520 A A
Max Load: 2469 lbs.
Tread Depth: 11/32"
Meas. Rim Width: 8"
Tread Width: 8.9"
Revs Per Mile: 678
And the Michelin:
UTQG Data: 440 A A
Max Load: 2245 lbs.
Meas. Rim Width: 8"
Tread Width: 8.7"
Revs Per Mile: 679
