I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
Desmo Variable Valve Timing Video
by LoneRanger
05/02/16 06:29 PM
Avalanche
by 94 saturn sl1 2000 saturn sc2
05/02/16 06:15 PM
Bardahl
by jk_636
05/02/16 05:54 PM
'96 Chrysler Sebring with 2.4
by outoforder
05/02/16 05:23 PM
Accident, no citation, insurance?
by Throt
05/02/16 04:58 PM
Got a Speeding Ticket today
by larryinnewyork
05/02/16 04:39 PM
Anyone remember "in living color" ?
by car51
05/02/16 04:14 PM
schedule / oil recom. for 2015 Honda Accord V6
by Viche
05/02/16 03:38 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
117 registered (awoess, abycat, 06AllAmerican, asand1, 3800Series, Abakev, 10 invisible), 1883 Guests and 314 Spiders online.
57767 Members
66 Forums
248380 Topics
#3284125 - 02/16/14 01:51 PM Cleaning compressor sump: What to use?
ron in sc Offline
Loc: SC
I want to clean, this is, remove the sludge form my air compressor pump. It has a large inspection plate that I can remove to access entire sump. I've done it this way before many bolt to remove and then remove old gasket material and make new gasket.
I would like to clean it by adding some cleaner (????) with oil. Then run it and drain contents and refill with oil. What could I safely use that would work.
#3284161 - 02/16/14 02:16 PM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
95busa Offline
Loc: Tennessee
maybe MMO?
2005 Ford F250 Super Duty 4x4
2009 Dodge Grand Caravan
2014 Kia Forte KOUP- totaled by a drunk driver
#3284196 - 02/16/14 02:44 PM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
Sawdusted Offline
Loc: The Tropical Fine City
I would spray with brake parts cleaner after you remove the plate. If your bottom plate has waffle patterns, it'll be more difficult to remove the wear metals but it can be done.
Spray with compressed air to remove parts cleaner and then refill with whatever suitable oil.
2003 Lexus RX300, 1MZ-FE
2011 Volvo S60, 2.0T, B4024T6
#3300831 - 03/04/14 12:07 AM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
default Offline
Loc: Michigan
Replace ~10% of oil with kerosene.
#3300839 - 03/04/14 12:26 AM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
Clevy Offline
Loc: Saskatoon canada
Acetone,xylene,toluene. Any of these will work. If you've got a wire brush you can scrub the mud off.
However prior to disassembly I suggest running some mmo/seafoam in the pump. Overfill it so the mmo/oil splashes up against the bottom of the piston. Open the tanks draincock so the compressor can run full blast with minimal resistance.
Once you've run the compressor for a half hour or so drain and let cool.
Then use one of the solvents listed and a wire brush to clean whatever's left.
After the mmo/seafoam flush I doubt there'll be much to hand clean.
Some compressors allow the use of m1 15w-50 in the pumps. That or some syn v-twin oil would maintain cleanliness.
If using a detergified engine oil in the compressor pump I strongly suggest looking through the sight glass for air bubbles and if you see some you have to use ND-30. It won't bubble but since its non detergent it won't clean either.
2006 Charger RT
Miles x 2 per oil filter
#3308414 - 03/11/14 03:26 PM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
camelCase Offline
Loc: Southeastern, USA
If you can get your hands on some d-limonene that'd be the trick.
Could also give chapala filter (http://www.jchapala.com/lubricants.php) a call and ask for their cleaner concentrate. You put 10-20% of sump capacity in, run for a week, then drain and fill with fresh fluid. Works every time.
#3335013 - 04/06/14 02:08 PM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
ac_tc Offline
Loc: sweden
Drain and fill, run for a short period like 2 minutes , drain and refill, done.
- I think your making a simple change way to complicated..
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3352020 - 04/24/14 02:23 PM Re: Cleaning compressor sump: What to use? [Re: ac_tc]
camelCase Offline
Depending on the deposits he has - that won't do much for him. If he did that first fill cut w/ 10-20% of a solvent like kerosene (cheapest and easiest to find compared to toluene or any of those) then he's on the right track.
If you want a long term easy solution - fill it with a diester fluid and spend the rest of your money on a few oil filters.
#3387555 - 06/03/14 04:37 AM Re: Cleaning compressor sump: What to use? [Re: ron in sc]
Olas Offline
Loc: Manchester, England
strip it and get busy with the brake cleaner, wire brush and shop towel.
easy
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
