Trans Pacific Partnership
by Merkava_4
02/07/16 09:57 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
02/07/16 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
02/07/16 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
02/07/16 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
02/07/16 08:51 PM
Ever wonder how the new Camaro is made?
by BobsArmory
02/07/16 08:43 PM
Credit Card Reader 4 Smart Phone-Small Business
by crazyoildude
02/07/16 08:16 PM
talent doesn't pay like it used to.
by motor_oil_madman
02/07/16 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
02/07/16 06:58 PM
Valvoline white bottle 2.99 at Menard's.
by jhellwig
02/07/16 06:47 PM
EZ Car Lift Review
by JHZR2
02/07/16 06:32 PM
What oil for a beater vehicle?
by car51
02/07/16 06:01 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
93 registered (05LGTLtd, anl0109, 87sammy, 901Memphis, 74DartSport, Astro14, 8 invisible), 1152 Guests and 206 Spiders online.
56846 Members
66 Forums
244393 Topics
Page 1 of 2 1 2 >
#3387306 - 06/02/14 08:09 PM Recommend R134a refridgerant
Da Game Offline
Loc: Chicago
I'm preparing to service my AC unit in the wifes car. I need you guys opinion, what is the better brand of R134a Syn or other wise out there? The AC was blowing hot Sunday so just tring to stay ahead of the heat. Oh, I have to buy the AC manifold Guage set, no one rents them out.
#3387322 - 06/02/14 08:21 PM Re: Recommend R134a refridgerant [Re: Da Game]
Donald Online   content
Loc: Upstate NY
First why does it need service? Its a closed system.
You need a manifold gauge set, an A/C duct temp probe (cheap) and some plain R134a from NAPA. No "stop leak" added to the R134a.
If the system is low on R134a then there is a leak. The best solution is to find the leak and repair/replace what is leaking. Then evacuate the system, verify it holds a vacuum and refill with the exact weight of R134a as listed on a hood sticker.
Also the manifold gauge set should be purged of air before the valves are opened.
I would dump in one can of R134a and see if it helps the cooling. If it does not, bring it somewhere.
There is some knowledge that is needed to work on a car's A/C. And some expensive tools.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3387328 - 06/02/14 08:28 PM Re: Recommend R134a refridgerant [Re: Da Game]
Chris142 Online   content
Loc: apple valley, ca
R134a is the same regardless of brand. Dont use any with sealers or stop leak
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3387332 - 06/02/14 08:34 PM Re: Recommend R134a refridgerant [Re: Da Game]
Mackelroy Offline
Loc: Florida /Texas
Auto zone carries a charge kit, one large can with valve meter unit included, for about $35.
also has instructions, the key thing is to make sure the compressor is cycling, or you wont get good readings. compressor on full cold with internal recycle button also pushed.
More than likely you have a leak, so its a $35 gamble to see any benefit, but that's the whole package , if you get no result, you'll just have to take it to the shop..
Edited by Mackelroy (06/02/14 08:36 PM)
#3387345 - 06/02/14 09:02 PM Re: Recommend R134a refridgerant [Re: Da Game]
Quest Offline
Loc: beaver land EH?
+1 with what Donald and Chris142 said.
DO NOT! I repeat: DO NOT tempt fate (if you don't know how to service A/C systems properly) with those A/C in a can with leak sealers in it.
Most A/C shops use A/C refrigerant recovery systems which, if sealer is present in the customer's car, will ruin their machines, costing hundreds, if not thousands of dollars of damage (which would require downtime to service the machine).
If they find you lied about having sealers in your systems, you are in a very interesting "surprise".
Proper A/C servicing requires vacuum pull-down and hold for at least 30mins or more. Injection of A/C oil dye to aid with the diagnosis of A/C leaks is the proper way to do it.
Bottomline: you don't know how to do it, or if you don't have proper machine (or even the gauge set + vacuum pump) to deal with it, don't do it.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3387346 - 06/02/14 09:03 PM Re: Recommend R134a refridgerant [Re: Da Game]
artificialist Offline
Loc: Florida
I am used to seeing cars simply lose refrigerant gradually. I have successfully saved 3 cars in my family through adding refrigerant from cans.
In the past, my father was able to do the same thing. He had a 1979 Toyota and 1987 Hyundai Excel that could be made to blow cold by adding refrigerant every few years. Mom's 1985 Nissan Maxima was a different story, that car suffered from a bad air conditioning design, and suffered compressor and condenser failures more than once.
Use only R-134a that has no sealants or additives that say they improve performance. Also, you don't need one that adds oil, because PAG refrigerant oil tends not to leak out unless a major failure happens. The only additive that your can of R-134a can have is leak detection dye.
2010 Lancer Ralliart Sportback
#3387354 - 06/02/14 09:13 PM Re: Recommend R134a refridgerant [Re: artificialist]
Loc: Upstate NY
They probably have o-rings that are slowly leaking. Thats why I suggested to add one can and see if it helps. Don't add a second can whether it helps or not.
I know they sell cheapo kits with a gauge for the low side and a can of R134a. You really need the high pressure gauge also.
If you do not have a manifold gauge set + vacuum pump then its doubtful you have the knowledge to do it properly.
#3387417 - 06/02/14 10:23 PM Re: Recommend R134a refridgerant [Re: Da Game]
bvance554 Offline
Loc: VA
OP did you say R134 Syn or otherwise? If you're looking for synthetic R134 i can help you out. I have a stash in my basement that I accumulated before the synthetic version was banned. It is the best, but it will cost ya!
#3387443 - 06/02/14 10:39 PM Re: Recommend R134a refridgerant [Re: Chris142]
bdcardinal Offline
Loc: Santa Barbara, CA
Yup, it is all licensed by DuPont, the real name is DuPont Suva. Do not use anything with sealers, if you do and take it to a shop, you will be on the hook for the thousands in repairs to their equipment.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Patron Member
#3387539 - 06/03/14 01:13 AM Re: Recommend R134a refridgerant [Re: bdcardinal]
earlyre Online   sleepy
Loc: Lima, Ohio, USA
ok... I obviously have a leak in mine(low side was only reading 10psi when i started), and i did what everyone is saying NOT to do.(2 cans-18&12oz, both with stop leak, using the included low side only gauge/hose) I have a appointment @ the Ford dealership this friday to have them check out the system.
so what do they do if some one tells them they DID use a stop leak product? am i just SOL?, Do i get to pay for an entire new A/C kit for my Sable? (iirc ~$1000) or do they have a different system to handle the Contaminated systems of us "helpful Idiots" in the Gen. Populace?
Mine:
09 Mercury Sable : 6qts Motorcraft blend 5w20, Motorcraft Fl-400s
Mine to Maintain:
03 Pontiac Vibe : 4.5qts GC 0w30, Fram XG4967
#3387551 - 06/03/14 02:27 AM Re: Recommend R134a refridgerant [Re: Da Game]
yonyon Offline
Loc: NJ, USA
Bring the can of junk to the shop with you so they know what you put in there.
If the stop leak is just a seal conditioner, a solvent flush and a new dryer will take care of the problem. This won't cost too much.
If a glue-type stop-leak was used it will be necessary to replace the orifice tube and leave the system open to air for a while so the glue can set up inside your car rather than the recycler. An inline filter may be installed to keep the compressor from self-destructing. The condenser and evaporator will likely be damaged as well, but still usable if you're willing to accept reduced cooling efficiency.
#3387667 - 06/03/14 08:45 AM Re: Recommend R134a refridgerant [Re: Da Game]
I just bought a $520 filter that traps stop leak before it can get into my machine
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3387695 - 06/03/14 09:33 AM Re: Recommend R134a refridgerant [Re: Da Game]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
Brand of r134a does not matter. As per everyone else, buy the stuff that's just plain r134a with no additives. If you need to add things like dye or oil, you can do that yourself just the same, and at least that way, you are adding the right grade of oil.
#3387790 - 06/03/14 11:18 AM Re: Recommend R134a refridgerant [Re: yonyon]
thanks for being debbie downer...
those cans hit the landfill about 2 weeks ago...
but they were these:
http://idqusa.com/product/345_r-134asubzerosyntheticautoacrechargekit
http://idqusa.com/product/acp-105-ac-pro-advanced-stop-leak-professional-formula-r-134a-refrigerant
since i don't have the actual cans, would printing out the MSDS's do anything for the dealership?
Edited by earlyre (06/03/14 11:22 AM)
Mine:
Mine to Maintain:
#3387864 - 06/03/14 12:52 PM Re: Recommend R134a refridgerant [Re: bdcardinal]
I understand what you are saying. But,the problem i have with that is in the case of a recently purchased used car.
Using a loosely modified version of My scenario as an example: I just bought this car in Jan.
If i had taken it in before adding anything, would tell them the truth, i added nothing.
so they hook it up, and their works gets all gummed up b/c the Previous owner, (unbeknownst to me) had dosed the system with stop leak.
Why should I be on the hook for equipment when I had no way of knowing the stuff was in the system?
Edited by earlyre (06/03/14 12:56 PM)
Mine:
Mine to Maintain:
Page 1 of 2 1 2 >
