I've read the hype, and believe that it's good at killing something.
I have been involved int he construction of two industrial plants, and for industrial water treatment it is VERY VERY good. Chlorine Dioxide is capable of getting into the slime that holds the legionalla and killing, while plain old Chlorine has to oxidise it's way into the slime.
Better from a WH and S point of view, as instead of cylinders of chlorine gas at a couple hundered psi, the ingredients are hypo/hydrogen peroxide mix, and sulfuric acid.
Once formed, it's mega corrosive, needing teflon lined pipes/valves.
As to taking it internally, not sure if I would, but the doses talked about are pretty small. Same for MMS2, which is taking capsules with calcium hypochlorite, and letting the stomach acid do the work...if I was in dire straights, I would...would also use it to purify water in the next Y2K scenario.
Can comment on using it for nail fungus type things...couple tablespoons of hypo, and some citric/acetic acid in the shower to swish around the feet, I have done.
