Replacing the wornout bearings on a 2001 sc1. Pressed the bearing and hub out. The bearing of course separated and i ground the inner race off the hub. There is a slight flat spot on the hub shaft. As long as i smooth it up, is there any reason not to use these and press them in to the new bearings? I already ordered timkin bearings. You can't buy a hub by itself, only a hub with bearings or bearings alone.
Hoping Trav sees this post.
