It could be either then....
On manual Subaru's & in Chevy's case the Trailblazer SS they used viscous center diffs with no lockup that tried to keep the power always at 50/50. If a difference occurred the fluid would heat up and cause a semi-lock condition to try and bring it back in check.
Yours could be that or a center diff with planetary gears which from what I read keeps it 60/40 which might also have some form of lockup. Depends though...
Taking the vin to a dealer should let you know for sure.
